- 23 Feb 2011
Hi all,
Just finished building my gaming pc and have a few questions...
Computer Case : Cooler Master CM-690 II Advanced dominator
CPU : Intel Core i5 2500k (4 x 3.30GHz)
CPU Heatsink : Cool master Hyper 212 plus
Memory : OCZ Platinum 4GB (2X2GB) 1600MHz
Graphics Card : 2 x ATI Radeon HD 6970
Motherboard : 1 x Asus P8P67 Pro Intel P67 DDR3 *Revision B3*
Sound Card : N/A
Networking : 1 x Motherboard Integrated Ethernet Lan (Broadband Ready)
USB Ports : 1 x 6 x USB 2.0 Ports & 2 x USB 3.0 Ports
Firewire Ports : 1 x 1 Port Firewire IEEE 1394 (Built In)
Power Supply : 1 x XFX PRO 750 Core edition power supply
Hard Drive #1 : Seagate Barracuda 7200.12 1TB sata-II 32MB
Optical Drive #1 : 1 x Samsung (SH-S223C/BEBE) 22 x DVD
Monitor : BenQ G925HDA 18.5" Widescreen LCD monitor - Black
Sound System : Edifier R1600T Studio Plus 2.0 Monitor
What is the normal post build procedure? What should I be adjusting, installing in terms of software progs ( apart from the drivers etc that came with the components). Also I plugged both my optical drive and Hard disk into the navy blue sata 6 ports, and on the manual it mentions not to insert n e ATAPI Devices. Ideas?
Also sometimes when i boot it up, it boots itself up twice in a matter of 10 seconds for some reason, any ideas?
Thanks
Sound Card : N/A
Thanks
