Hi all,
I am planning on sending a package to Brazil the contents are worth £600 so will need to be insured for this.
The package is a gift and so will be declared as this. Am i correct in thinking this will mean i do not have to pay custom fees?
The guy i'm sending it to said also said i should insure the item as 600 but try and put the value as only £60 as this will aviod customs.
Can anyone recommend a service to use? I am thinking of using UPS.
Cheers!
Edd
Cheers!
Edd
