Hey all, sorry if this is the wrong section. I wasn't sure whether to put it in motherboards, as I'm really not sure if that is the actual problem.
I recently upgraded to a 5600 from a 3100. It was fine for 1 month or so, then I began to experience high temps and random restarts with the event viewer saying Kernel Power 41. WhoCrashed gave no info.
I figured it was a temp issue as I was still using the tiny stock cooler from the 3100.. got a new ThermalRight cooler and idling at 35-40, load 60-70. Great..but it is still restarting with the error
I posted on a forum and was told the PSU was the likely suspect, as my old one was a D tier seasonic. so got a new 750w gold+..same issue.
I put the old 3100 in to see if it was the 5600 breaking and i am still getting the error with the 3100.
This leads me to believe the mobo is not pushing enough power, or consistent power. I have tried many things, different PBO settings, DDU gfx drivers, reseat all cables and cooler, etc.
The only thing that seems to make a difference is PBO/eco mode. It lasts longer before a restart with no PBO and eco mode enabled but not much longer..
Specs:
5600/3100.
B550 Pro VDH Wifi.
1660 Súper.
2x16gb
ThermalRight king assassin 120 SE cooler
Any help appreciated. Have already replaced the PSU and cooler and am a bit annoyed that it isn’t solved yet haha
Specs:
5600/3100.
B550 Pro VDH Wifi.
1660 Súper.
2x16gb
[it was garbage].
