Potential problem with my HDD's
18 Oct 2002
So you know what im running first
My Media Centre
e8200 @ stock
Gigabyte P35 DS3R
Corsair620w PSU
4x 500 gig F1 samsungs in Raid 5 using the mobo controller
1x 160 gig samsung
ATi 2600 Pro
PCi Express XFi
Hauppage HVR 1300
Running Vista 32bit.
I keep getting, and most notably when I use Itunes, basically, a 10 ish second hold on the pc. CPU usage goes up to 50% ish, and the hdd light flashes once a second.
Im sure its probably something quite straightforward to resolve, but does anyone have any ideas please?
I've just been recording something in vista media centre, and swapped over to itunes to put on some music. upon doingthis the hard drive light started to flash and it actually stopped the recording on media centre, and then it restarted after it had finished its paddy.....
Just now also when closing speedfan to see if there was any smart data the music playing jittered madly like a stuck cd whilst the HDD light flashed at me. then carried on as though nothing had happened ...
Flashing on the Hard Drive light is slow and constant like an indicator in the car... if that helps
Importantly here also, media centre records to the raid 5 array, and the itunes songs are on there also...its been suggested its the array initialising, if this is the case,how do I keep it permanently intiialised?
What does the Intel Matrix Storage app say about the state of the RAID5 array?
If your swapfile is on the RAID5 array get it onto the other drive for a start, Vista doesn't use the swapfile quite as actively as XP but even so you really don't want a file with heavy write activity on a mobo based RAID5 array if you can help it.
Thanks for your reply.
Status is 'Normal' but when I had vista 64 ultimate on this machine I had the same issues, and it was always saying 'Initialising'
Swap file is now just on the C:|
