It seems my scanner adapter has stopped worked. I can buy one for about £9 with free shipping from the bay, but it could take up to a month from china. My scanner is an old HP scanjet 3300C, and this is what's written on the power adapter:
Input 200-240v
50Hz, 0.4A
Output +12VDC/1.25A
Can I just buy an appropriate power adapter locally from somewhere? And of course, even with the correct voltage and ampage, I need one that's going to fit the socket of the scanner. Is this going to be difficult to find a match and maybe I should just order from the bay?
Input 200-240v
50Hz, 0.4A
Output +12VDC/1.25A
I asked the seller if he thinks the barrel will fit my scanner. He said he looked up the adapter tip specification and its compatible with my model.
