*Rookie question warning*
I'm after a power bank for my vape, they sell an official one for £25:
thejuicyjoint.co.uk
It is 5000mAh. On Amazon there are loads with larger capacity for cheaper, and some have 20W PD which would be useful for my phone too. However, I am concerned they may negatively impact battery life.
I'm struggling to find details on the battery, but the vape is a Zeus Arc GTS, it has a 3500mAh capacity and a micro USB charge port. I currently charge it using a USB A 5V/2.4A charger port, this works fine.
Would I be fine just buying any power bank, or do I need to consider specific specs etc? Should I just get their official one?
Thanks
Zeus Charge - Portable Power Bank
The Zeus Charge is the most convenient way to power your vaporizer when you are away from an energy source. Featuring 5000mAh of power and a portable design the Zeus Charge is compatible with most USB charging vaporizers. It is also designed to fit inside the Zeus Armor Case. Warranty: 1 Year...
thejuicyjoint.co.uk
Thanks
