Power blips/brownouts
I was on a training course yesterday and the trainer was working from home and had a series of brownouts where the lights flicker but power doesn't go off completely. This happened a few times and other people from other areas of the country said the same thing was happening to them at different times. It made me think as recently we had a series of three, followed by another series of three on the same night.
Anyone else had this?
Is it aliens?
Do I need a tin foil hat?
We had them a lot, and some complete blackouts that lasted anything from minutes to hours.
Apparently the incoming feed to one side of the town was over capacity (yay for building masses of new homes, but no infrastructure), this went on for several years where we'd get little blips on the lights and sometimes the TV would turn off but the PC's would often be fine (advantage of over speccing the PSU) as the various substations tried to switch feeds or did fast resets. For a while we had times where literally half the town would go dark for a while, and if you were on the highstreet you might see one side with no power and the shops on the other side operating fine (it seems that one side of the centre was fed from one main substation on one side of the town that went out, and the other side from another that stayed up).
It only stopped when the distribution company built a battery farm as the fastest/cheapest way to fix the problem, apparently it was going to take years longer to actually run a new high voltage/high capacity line into the town, than it was to get planning permission, design and build the battery barn.
When you've got the sort of weather we've had the last few days the grid is under a lot more stress and more likely to have blips as things like branches and blown rubbish hitting the overhead lines can cause momentary shorts that might trip a breaker but clear before it goes down fully (IIRC a lot of them will automatically reset after X time, but if they have to do it more than 3 or 5 times in a set period they'll then go down on the assumption it's not a momentary issue), from memory that can cause blips in surrounding areas as the grid tries to reroute/substations etc try to swap over to another feed if there is one available and the voltage drops as it happen due to the load remaining the same but supply struggling. I'm probably really mangling the explanation :p
We noticed the lights flickering a few times Saturday (so before the storm), Sunday and a couple of times yesterday at work, I've seen nothing elsewhere though, definitely nothing at home so far.
I cannot think of anything more ridiculous, encouraging people to binge on power use and all at the same time.
So you don't agree with set meal times?
Remember when most people worked 9-5, everyone was encouraged to wake up at the same time ! it was crazy man! what were they thinking
:D
All the houses in my street had a power cut a few years back- except mine.
It was really weirdstand my neighbour seemed really angry mine hadn't gone, too.
Lol we had a similar thing a few months back. Odd houses were on, evens off. Then all off, then just odds back. Was super annoying.
Had similar when they did planned work a few weeks ago, there is 2 supplies to my village and apparently they can't tell remotely which we are on! so we still had power when all but 3 other houses in the village were off.
(The power comes in here on overhead lines so I'd have thought it would be easy enough for them to tell).
