Hmmmmmm......
Not sure i buy it.
As i see it oils can have no advantages other than extraction of heat and engine wear.
Power increases just seem a little bs??
was the "normal" oil they used old, or fresh stuff too? Maybe its just an improvement from running new oil.
It's Millers so it should be good quality but the "spherical nanoparticles" parts sounds exactly the same as ZX-1 that you put into normal oil to have the same effect (fills the "pits" in metal surfaces same as the Millers stuff)
Lubrication improvements perhaps?!
