I'm getting a couple case fans but am a bit confused about how to power them.
These 2 cables are confusing me:
Akasa 3-Pin to 4-Pin Adapter Cable
Akasa AK-CB423-ADPT 4 - 3pin adapter cable
I never done this before but I assume I need to convert some 4 pin molexes to 3-pins. So in theory I need a cable that has a 4-pin female on one end and a 3-pin female on the other.
So which one do I need....?
Akasa 3-Pin to 4-Pin Adapter Cable: Judging from the title it seems like it's not what I need, but if you look at the image, it has a 4 pin female and a 3 pin female and another 3 pin male, so that's what I assume I need.
Akasa AK-CB423-ADPT 4 - 3pin adapter cable: Judging from the title, this seems like the one, but as you can see in the image it has a 4-pin male and female and a 3 pin male so nowhere to plug-in the fan.
Please someone get me out of this missery!!
P.S. These are the fans I'm going for, I you got any suggestions for better ones, don't be shy
O, and this I my PC's blueprint so far if that helps...
