- 20 Aug 2007
- Solihull
Hi guys,
I've been asked to spec up potential max power drawer for a server room in a new building for a customer. The electrician has requested to know what kinda circuit/breakers need to go in. It's only a small company and will be using the below (Wattage estimated based on W=VxA).
I believe we've already specced the UPS (a colleague has) - Fujitsu APC Smart-UPS and MNGT card 1500VA LCD RM 1U 230V (SMX1500RMI2U + AP9630)
Does this look correct? Based on this wattage what would you guys recommend I have fitted for this room? I also need to work out the max load in volts and amps, is it possible to reverse engineer that from the total wattages?
Thanks guys!
Jamie
- ADVA FSP150CP (Fibre/Copper converter) - 40W
- ADVA FSP150CCf (Copper Multiplexor) - 120W
- Huawei AR1200 (Voice Router) - 160W
- Huawei AR200 (Data Router) - 36W
- Cisco Catalyst 48 Port Switch - 370W
- Dlink DSR1000AC Router - 24W
- Dlink DGS-1510-28p - 238W
- Fujitsu RX2540 M2 378W
- Seagate 3TB Backup Drive - N/A
Thanks guys!
Jamie
