power consumption
12 Nov 2002
In my own little world
After recently buying a shuttle and realising the limitations of components due to the power supply it has got my checking the power consumption of all my upgrades. I also picked up a cheap power meter from a certain local electronics store for £8. I'm currently in the market for a new gfx but thought this would be an interesting thread to find out the actual power usage from each spec and the psu that's being used.
ok here's mine
Shuttle SG31G2
e6600 @ stock 2.4ghz
2x 2gb memory
1x 320gb hdd
dvdrw
250w shuttle psu (soon to be a 300w)
with onboard intel gfx 128mb (can be set upto 384mb max)
65w idle
85w load
with ATI x1550 256mb
85w idle
115w load
with ATI x1650 512mb
idle 85w
load 130w
next will hopefuly be an 8800 GTX
MW
Dont forget 2 things, firstly the plug in power meter measures power draw at 240v (well 230 these days). Your PSU is not 100% efficient, so at full load 250W, you should expect the meter to read around 315W.
Secondly, be carefull not to exceed the rated 12v amperage, should be printed on the PSU's label.
PS, I dont normally see my Q6700 + 8800GTX exceed 250W on my plugin meter, and I have a stack of fans, several disks, zip/floppy/fan controller, a bunch of usb devices etc. You should be able to get away with the GTX as long as the 12V rail can handle it.
The amps was my next worry after the wattage. These 2 PSUs are 70% and 72% efficient at 100% load
current PSU
new PSU
I was hoping other members would post their specs and power consumption too
MW
Ok
Specs
E8400 @ stock 3GHz
Gigabyte EP35 DS3R
8GB GSkill PC2-8500
XFX 8800GTX @ 600Mhz
3 7200 HD
1 DVD-RW
5 120mm fans
Seasonic S12 600 PSU
183w Idle
245w WoW
356W OCCT power supply Benchmark
Also tested..
E8600 @ 3.6ghz
4gb ram 6400
4gb ready boost
8800gtx 768mb
2x hdd in RAID 0
dvdrw
corsair 450w
190w idle
350w load
MW
DFI 790FXB-M2RSH
Phenom 940 @ 3.7ghz, NB/HTT 2.4ghz
8GB 8500
4850 512MB
5 hdd
4 DVD±RW, 1 Blu-Ray Rewriter/HD-DVD ROM
X-Fi XtremeGamer
1 32cm fan, 1 25cm fan, 1 17cm fan, 1 12cm fan
Hi-Power 900W Modular
248w idle
356w load
