Bit of tourbleshooting for a power issue if you would.......
Twice tonight, whilst playing F1 2010, my rig has just powered out totally, as if someone had just pulled the plug out.
It has happened once before as well whilst playing L4D2.
Most of the rig is only a month old, the PSU is about 3 years old and I never had any problems with it before, which makes me think its something to do with the new setup.
I am running:
Asus P67 Sabertooth
i7 2600k 3.4GHz
Asus HD 6950 Direct CU II
16GB Corsair XMS3 1600
Engermax Galaxy EGA1000
Cut only happens when under load it would seem. Just in windows / web browsing it has never happened.
Memtest is OK.
I am thinking it could be the GPU or maybe even something to do with CPU?
Everything is seated fine. Nothing is overclocked.
Got me baffled a bit, not one I have come across before. I dont have a spare PSU to try and am a bit loathed at spending monies on one when I dont think that is it.
I do have a 8800 Ultra sat in a box, but it is half broken as it shows up red wavy lines over the screen, so not the best to test with.
Any ideas I can try before having to resort to buying new bits to test with?
I am running:
Asus P67 Sabertooth
i7 2600k 3.4GHz
Memtest is OK.
try again
