Power Cutting Out.....
Event viewer shows critical events Kernel-Power event ID 41 with the following info:
System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2011-07-18T21:50:51.249634700Z
EventRecordID 54140
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer MikeOPC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
Shows up the same for each time its happened, but with different time stamps.
I did a full system rebuild a few months back, but hadnt really played the game before then. Will have a look and see if the BIOS has any updates. Im pretty sure the PSU is fine since it doesnt happen in anything else apart from this game.
http://www.eventid.net/display.asp?eventid=41
Reading up a bit about it, EventID 41 games.
The event happens when the computer powers down inexpectedly. So it's more a consequence than a cause. Could be anything, but some core component is highly unstable. There is no bug code, and it's not a 'sleep' error, or triggered by a button reset.
Update drivers and bios first (motherboard and GPU). Then run some tests on memory, CPU, and GPU separately.
