Power/Display issue
3 Jan 2021
Hello, I just built my new system this evening. It worked perfectly fine for around 30 mins and then after I changed xmp in bios, I lost all display. I did the usual reseat GPU and tried my previous GPU, tried different monitor + dp cable but still nothing and then for whatever reason. Im not getting power to the system anymore. Any ideas. Thanks
No idea what my power issue was but I was able to short the CMOS which has given me display again. I'm running 3600mhz ram but the xmp seems to have caused the issue. What can I do?
Need to know the specs of your system, but it sounds like the RAM when using XMP is incompatible with the motherboard.
MSI RTX 3080 Trio
AMD Ryzen 7 5800x
4x8gb Corsair vengeance RGB pro 3600mhz
MSI mpg x570 gaming pro carbon WiFi
Latest bios? 3600+ is a bit of a lottery with Ryzen 5xxx at the moment. It sounds like what happened to me when I bumped mine up to 3800.
You could try manually configuring it, but you may have to settle for 3200 with tighter timings for now.
