- 11 Oct 2009
Hi guys,
I'm looking to get a 980 soon, but want to check that my psu can handle it. It's a Cooler master Silent Pro 500w - http://www.coolermaster.com/service/support/model/RS-500-AMBA-D3/
Currently powering an i5 4670k @stock, xfx 7950 with 10% clock core speed overclock, 2 disk drives, 1 ssd, 1 bluray drive, and 3 200mm fans. I did however need to increase the power setting in ccc to prevent it from being throttled.
I've put a device between my pc and the wall to see how much power im using, and currently, under 100% gpu load, ~60-80% cpu load, my system pulls ~280w. Can this support a 980?
On a different note but still about a 980, I have 3 monitors and 2 mini display port to dvi active adapters, if I get 2 display port to mini dp will that still work for multimonitor gaming?
Thanks
Thanks
