power from a mac
Would this help?
( http://www.apple.com/macmini/specs.html )
Electrical and environmental requirements
* Meets ENERGY STAR requirements
* Line voltage: 100-240V AC
* Frequency: 50Hz to 60Hz, single phase
* Maximum continuous power: 110W
* Operating temperature: 50° to 95° F (10° to 35° C)
* Storage temperature: -40° to 116° F (-40° to 47° C)
* Relative humidity: 5% to 95% noncondensing
* Maximum altitude: 10,000 feet
JIM_BOB7813 said:
Can't you calculate the amps (current, I) from knowing the power (Watts) and the voltate (230v)?
IIRC, p=vi -> i=p/v
= 110/230
=0.47 amps??
Could be wrong :o
That's right :)
wattage divided by voltage = amperage
kva times 1000 divided by the voltage = amperage
so you only need a 500mA or above supply
Clarkey said:
current...
there is no such thing as amperage :/
Technically that is true but if you're being a stickler like that you must also hold that there is no such thing as voltage, there is only electric potential difference.
