Power hungry cards?
14 Feb 2004
Livingston
Looking for a new gfx card and seeing a lot recommend 600w or above psu. I have a corsair HX520w. It really new psu time or will it manage. Been mainly looking at 390s but open to suggestions.
Yer prolly shouldve done abit more research 970 looks ideal was just drawn in by those 8gb cards. Still running an old i5 2500k and an md 7950
According to Corsair Link software my spec in sig uses approx 400+ watts with everything at stock during a gaming session. Depending on the rating of your powersupply and it's age, you maybe fine, but you will be pushing your powersupply.
He'll be fine on a HX520W + GTX 970.
I had an i7 920 @ 4GHz + GTX 470 (furnace) on a HX520W and it ran fine.
PSU recommendations are typically inflated to cover poor quality PSUs that don't live up to their specification. A decent 520W PSU like yours will be fine for any single card. For instance I have an AMD Fury which is nominally 275W, the same as the 390. Along with my 95W CPU, my system peaks at 400W measured at the wall (360W DC assuming 90% efficiency), leaving plenty of headroom with my 500W PSU.
