Power my 980ti
Caporegime
24 Dec 2005
Autonomy
I've only got one 8 pin PCI connector on my psu...
The card comes with a 2x 6 pin to 8 pin connector ...
Do I connect 1x 6 pin to it from the psu or 2 X 6 pin ?
It must be old as I can't find it. If it's some dated 5 year old relic with only one Pcie power then no, I personally wouldn't use it.
They are a pretty old unit, i had one at least 6 years ago. Very high quality psu at the time, though iirc mine had several pcie connections.
Iv'e sorted it...I found a second 6 pin pci-e connector in Enermax box connected it to the psu and then fitted both of them to a dual 6 pin to 1 x 8 pin adaptor that came with the card...
Then I used a 2 x molex to 1 x 8 pin and connected the other 8 pin to the 980 ti
Yes I have an 980ti :D
Money shot
Money shot
amazing looking card, jealous! :D
Running dual molex to 8 pin on a 980TI Poseidon Platinum!!!! :eek:
Buy a new PSU you spend-thrift/cheapskate, you make no sense. :p ;)
:p
I have a 900 w corsair HM but it's in my music PC running a passive amd 6450 in the studio :D
I'm just to lazy to swap them over :)
Seems stable enough :p
Id still swap them over. Peace of mind and all that. Nice choice of card btw.:)
