Power Problem
2 Oct 2010
HIS ATI Radeon HD 5870 iCooler V 1024MB GDDR5 PCI-Express Graphics Card
Intel Core i7 950 3.06GHz (Bloomfield) (Socket LGA1366) - Retail
Crucial RealSSD C300 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC128MAG-1G1)
Coolermaster HAF X Gaming Full Tower Case
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard
Cooler Master Silent Pro Modular 850W Power Supply
LG BH10LS30 10x BluRay-RW / 16 x DVD±RW Drive - Black (Retail)
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz Low Latency Triple Channel
CoolIT Vantage Liquid CPU Cooler
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) * 2
Edimax EW-7727In nMax 300Mbps Wireless Desktop PCI Network Adapter
LG GH22NS50 22x DVD±RW SATA ReWriter (Black) - Retail
NZXT LCD fan control
Antec LCD Multimedia Front Panel
Running Windows 7 Professional
I built it back in October/November where I had a few problems including one of the Antec LCD FP wires was in the wrong place and it smoked. I had a guy come in and replace the wire and all seemed fine.
Before that problem however there were still 6 post beeps which to this day still occur. After looking through BG’s manual I found it probably meant there was a power problem. The computer worked fine but there were/are these beeps.
Recently the situations getting weird, the usb at the front of the case is now sparking if anything is put in/near it then crashes the PC instantly. There’s still power travelling through the PC since the multimedia front panel briefly goes dark and then is re-lit. Any ideas folks?
Have you checked for any shorts in your case? Your motherboard could be shorting on the case somehow, this usually causes errors/ beeps as well.
It's probably the most common problem in new builds. It would also explain the beeping to indicate power problem, as it's probably being drained into the case.
You could also use a multi meter to test the 3V, 5V and 12V rails of one of the power supply molex, if you're not getting anywhere near the correct voltages, I recommend replacing your power supply...
