Power settings? game mode?
16 Sep 2010
Nottinghamshire
notice last night on windows 10 have a few more options than what i was used to back in the day I had a pc rig (13 years ago) on windows xp and windows 7
Power settings I have balanced and AMD ryzen setting which one should I use? I think as default it was on the AMD ryzen one?
Also game mode am I leaving this on also?
How do these settings impact anything?
Thanks
Found it Ryzen balanced it was actually under the windows set of options. Think I will leave it on Ryzen high performance as according to HW monitor the cpu was running at boost in games of 4.6ghz without it im running around 4.4ghz :confused:
Just done this - saves some clicking. I like it :)
Also, in my BIOS my PC is set to come on at 7am, it takes an image of drive C and opens all game clients to update.
I copied the balanced plan shortcut into the startup folder so the PC starts up in balanced plan which is set to sleep after 1 hour.
It's then updated and asleep by 8-9am. At which point I just wake it up whenever I need it and change to Ryzen balanced for the rest of the day.
