Power Supplies
9 Mar 2009
Newcastle
Hi guys, I'm teetering on the edge of buying a new bundle to upgrade my PC so I can use a capture card I bought that I couldn't then use.
This is the bundle i'm looking at:
http://www.overclockers.co.uk/showproduct.php?prodid=BU-029-OB
I was just wondering what you guys would recommend as a suitable power supply to go with that bundle.
It'll have that bundle, plus 512Mb graphics card, 2 (maybe 3) hard drives and two optical drives.
I don't need any overkill on it, just a good enough PSU to comfortably run all that with a decent amount of breathing space for any future additions.
Also, i'm not looking to spend a ton since money is tight, but if anyone could point me towards suitable modular PSUs i'd really appreciate it. My current PC is a mess of un-used power cables.
Thanks loads guys!
Bob
More than enough, my system which had crossfire 5850 and i7 @ 4ghz pulls 430w ~ full load from the mains.
ahh sweet. i knew that more is better really but i didn't want to go overboard and get a 1000watter or anything. Rather be safe than not have enough power though.
Thanks for replying so fast by the way.
Assuming i can pluck up the courage I'll buy my bundle and probs that BeQuiet! tomorrow.
Thanks
