Power Supply 12v rails
  • Thread starter Thread starter SkodaMart
  • Start date Start date
SkodaMart
SkodaMart
Power Supply 12v rails Question
My CoolerMaster Real Power M700 power supply has 4 12v rails, each capable of delivering 19A, however it only has 2 6 pin PCI-E ports
What would be the rated current on these PCI-E ports 19A?
I have noticed that modern SLi PSUs now have a single 12v rail that is capable of delivering a high current.
From a review
The specifications also show that the M700 has a healthy 25amps available to both it's +3.3v and +5v rails and 19amps to each of its four +12v rails (with a total combined load of 52amps).
The reason I am asking is I am currently running 2 x 260 GTX overclocked in SLi off my CoolerMaster M700 via 2 x Y leads from the 2 PCI-E ports.
I know the M700 is a quality power supply capable of supplying 850 W peak or 700 W constant, however I have just took advantage of the OCUK MSi Twin Frozr GTX 470 deal and intend to run them in SLi.
I suspect I may need to upgrade however It depends how many amps the PCI-E ports can provide.
it say 4 rails but really there is just one, its listed as 4 because on he way the cables come out of the PSU so the answer to your question is yes it will be ok as all 4 rails are really 1 rail split into 4 outputs
Well I have my doubts as to whether it would be a good idea to run GTX 470 SLI off the Cooler Master Real Power M700, as GTX 470s are much more power hungry than GTX 260s. And usually the recommendation I would make for such a system would be a good 750W PSU and the Real Power only claims 624 watts on it's 12V rails. You probably could try it out at least, but you should keep your eye on it while gaming.
@Aretenon. I am thinking pretty much the same to be honest, It might just be easier to sell it and get a new 1000 Watt job.
The only thing in my favour is that I have an i5 750 @ 3.4 Ghz at only 1.2v, that only draws around 100 W
