a few days ago my PC was fine i went to bed the next day i got up and it just started making weird noises coming from the psu
its like a rattling noise and it makes the whole case vibrate a lot
i removed the grate and wiggled the fan around a bit incase it was hitting on somthing put it back together but its still making a lot
the fan itself seemed a bit stiff but that wouldnt cause it to rattle and stuff would it?
any help is accepted can u replace the fans on psu?
its an OZC 750 watt not sure if it has any warrenty ( didnt remove the screw that has the sticker on it)
thanks guys
