Power Supply
28 Aug 2011
Hi, my power supply has stopped working, tested with a spare so need to buy a new one.
This is the one I am replacing;
http://www.coolermaster.com/product.php?product_id=3686
This is the one I am looking to get;
OCZ ZS Series 550W '80 Plus Bronze'
http://www.overclockers.co.uk/showproduct.php?prodid=CA-055-OC&groupid=701&catid=123&subcat=1098
Don't want to spend too much as am looking at a system upgrade later in the year..
System;
E5200 Core2Duo
G31M ES2l
9600GT
4 x SATA Drives
Coolermaster 340 Case
I don't know much about PSUs but if you are planning to upgrade don't you want to make sure the PSU can power your planned parts to save money in the long run?
The PSU is one of the only components that can truely be "futureproof" DO NOT skimp on it. What you get exactly really depends on your likely upgrade in the near future, but a good quality 750W would be capable of powering a very well specced system for quite a few years.
Unless your looking at going to multiple gpu setups then the 550w OCZ is fine for most needs.
Hi, thanks for the replies. The OCZ seems better than what I had and seems to have good enough components for the system and good reviews. I am thinking to use it as a media centre when I "finally" upgrade so want to keep it intact as a complete system.
For my new setup I am thinking a modular PSU with a bigger case should be first on my shopping list and after having my first ever PSU give up can appreciate how it is more important than the glamorous parts (GPU,CPU).
