power switch
Permabanned
18 Apr 2006
14 miles from OcUK
can you get aftermarket on off switches to turn your pc on and off ?
the switch on my antec p160 is a bit dodgy so i was wondering if i could replace it tempory like untill i get a new case
cheers
does anyone know if theres a power and reset combo available ?
i supose i could make some i just need to know what sort of switches i need
they wont be toggle switches, are they push to make switches or possibly push on push off :confused:
i bet theres some electronics heads on here somewhere :)
They are momentary push-to-make switches. Non-latching. You can use vandal resist push buttons. Which are expensive, but look cool.
cheers mate thats what i thought
just looking at them on a large electronics retailers site they do look pretty cool
does it matter which way you conect an led to the power/hdd headers, i mean do they have a deffinate + /- side ?
Yep. Leds do have a certain way round. Shorter wire is negative. Think its also the but with the flat on it. Dont worry if its round the wrong way, it just wont work.
