Thanks, I'll take a look, its crazy that some brands have different battery systems specific to a particular product range... They should put in industry standards that the companies have to adhere to.Theres CAS which have a few brands on there but they tend to be ones that don’t compete with each other.
Good brands like fischer and metabo are there as well as high end mafell and rothenberger
CAS: One battery for over 45 brands.
The CAS battery is a multi-brand system with Metabo technology. ► Simply combine your batteries and chargers with more than 45 brands.cordless-alliance-system.com
Apart from that it’s adaptors i’m afraid. Which is probably the way to go to get the best off all worlds.
