POWER!!!!!!
31 Mar 2013
Hi,
Doing a build and looking at two asus gtx 780s in sli the psu I was getting is the corsair ax 860i, will this do the job or is it cutting it a bit close? may be better with their ax 1200i? bit of a price jump but willing to pay if it means a stable build. thanks.
yea sure,
i5 4670k
asus z87 sabertooth
256 ssd
wd 2tb green
x2 asus 780's
16gb corsair vengeance pro gold 2400mhz x2 8gb
coolmaster haf x gaming case
dvd drive
corsair h80i
will be overclocking a little nothing major
Have you purchased all your components yet?? Cos if your wanting to run 2 780's i'd be wanting the 4770k in there, just to minimise a bottleneck.
Don't get the 860i, get the 860 without the i.
The 860i/760i are made by flextronics, where as the non-i are made by seasonic.
+ Corsair link, is shocking. Unless it's been fixed?
