Powering SAS Drive Question
30 Dec 2012
Hi All,
I have a WD4001FYYG SAS drive and want to know if it possible to get this recognised within a normal computer ?
I have purchased a SAS to Sata cable but when connecting it does not power up the hard drive ? Is there something more I need to do ? Do I need to jump any pins on the drive ?
This is the cable I bought
http://www.ebay.co.uk/itm/7-Pin-SAT...977507?hash=item210abb72a3:g:Q4AAAOSwPc9W0Cbt
Any help appreciated - is this possible what i want to do ?
Thanks.
The drive probably won't spin up until the SAS controller tells it to.
If you want to use a SAS drive you'll need a SAS controller of some sort. It won't work on a SATA controller even if you can physically connect it.
SATA controllers only support SATA drives.
SAS controllers support both SAS and SATA drives.
Thanks for the reply - could you recommend a SAS card ? I would be ideally after PCI-E 1x if possible .. or PCI - though i suspect there isn't a card with PCI connectivity ?
Also, is it possible to get a SAS card with SATA ports ? Then I can use that cable .. I am thinking it may be best to go mini sas though and then connect / power separately with the cable
Cheers.
