Pre-Build pc advice
Brilliant. :D
Just remember to take your time, read all the manuals and follow all the installation guides. Your mobo manual will be an enormous help.
If there is anything you are not to sure about, just post up your query and someone will point you in the right direction.
In regards to an SSD, if you afford afford one, yes. ;)
Good luck with the build.
And don` forget to post some piccies, before, during and after. :D
Heres your manual, if you want to get accustomed beforehand.
http://www.gigabyte.com/products/product-page.aspx?pid=4140#manual
Cheers man, Would I use the SSD to install windows on?
Ok ordered an ssd, Think it will come the day after the rest of my parts so that pretty annoying lol, When im ready to build ill be asking you guys lots of questionsso im just gonna appologise in advance :P
Gives you plenty of time to get it up and running.:D
so buying an older slower processor for the same price as a new faster one is a bad idea then? :D
difference between i5 3570k vs i5 2500k is 2-5%
Difference between the temps are 10-15% if not more in some cases...
OC - SB gets better results.
Hmm...
Thanks for the spec IC3 but as stulid mentioned I have already ordered my parts. Well guys, My order has arrived :D:D I will be making a thread in a bit when I start the build for help advice and just to let you all know how I am getting on. I would like to thank you all for the amazing feedback you guys gave me and a very big thankyou to idleman for sticking by me and making sure I was taken care of.
No worries i forgot to look at the day the thread was made...
