Pre built gaming pc ?
10 Dec 2012
Hi guys,
I'm looking to buy a pre built gaming pc that will hopefully be able to run 90% of games on max graphics, I have a budget of £1000 and wondered if you could suggest some gaming pc's to me (by the way I live in the uk)
Thanks
YOUR BASKET
1 x "Titan 8700i Pulse" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge Gaming PC £520
1 x Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) £79.99
1 x 24 MONTH WARRANTY - COLLECT & RETURN £0.01
1 x Sapphire HD 7850 2048MB GDDR5 PCI-Express Graphics Card w/ FARCRY3 & Sleeping Dogs PC Games £169.99
1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £79.99
1 x Standard Build Systems - Approximately 5-7 working days £0
1 x Opt Out of FREE AV Software £0.01
1 x No Sound Card Upgrade £0
1 x Samsung S24B300HL 23.6" Widescreen LED Monitor - Black £119.99
Total : £989.48 (includes shipping : £16.25).
The monitor is only £10 off until Wednesday... This doesn't include a wifi card either.
Upgrade to a 7950 if you don't need the monitor, maybe a 120GB SSD if you can stretch to that.
You will need to tell us exactly what you require and if you have any components that can be reused. Hdd/odd(sata), for instance. This will help you get the best system for your money.
And building yourself, is a lot cheaper, plus more satisfying.
I have no components to be reused, I have a monitor, mouse and keyboard, so will need and OS and a case and everything else and it will be just for gaming, I have no experience in building hence I would like a pre built system thanks guys so far, I also don't think I will need to buy a second hard drive.
Yeah, looks good!
If you can afford an SSD on it, go for it, you'll get great performance from Windows & any games/programs you install.
What does an SSD actually do ?
To someone with no experience it's essentially a hard drive with lower capacity.
However, it is massively more responsive and faster for all types of application. Loading screens in games begone etc.
The lower capacity is offset by buying a HDD for storage. In win7 you can make folders in the root of the drive for example 'programs, my pictures, my documents' etc and then set windows to use these folders as the default for the 'pictures' 'documents' etc libraries (this means word for example will try to save in these folders by default) and install less-used programs on the HDD.
edit: HDDs make a really annoying sound imo.
I could put the £200 towards a better pc as I have a monitor and peripherals, if you look at the 10th post would you be able to tell me if that pc is good enough to run 90% of games on max graphics please
