** PRE ORDER DISCOUNT - CORSAIR LTD EDITION K70 **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have a limited time offer on these Corsair keyboards.
This is a special limited run SKU of the K70 available with either MX Brown or MX Blue switches in the cool 'gun metal' brushed finish.
These will only be available from ourselves and two other key partners.
To celebrate, we are offering a nice discount on these boards whilst they are on pre order.
As I mentioned, they are Limited Edition so be quick if you want one with a discount.
Corsair Vengeance K70 Gunmetal Cherry MX Brown Mechanical Gaming Keyboard (CH-9000059-UK) @ £89.99 inc VAT
The Corsair K70 is a fully mechanical, backlit keyboard that’s designed for performance gaming. The built-in Cherry MX Brown switches deliver fast and precise response with light tactile feedback for comfortable typing. Every key is individually lit for brilliant backlighting and easy customizability to highlight important functions. The brushed aluminum structure provides rugged durability and a professional-grade finish. Replaceable contoured keycaps make it easier to find critical WASD keys—even in dim light. Plus the Full N Key Roll-over on USB and 100% Anti-Ghosting mean that every key you touch translates directly into the game.
Product Features:
- Cherry MX Brown Mechanical Switches - Fast and precise response with light tactile feedback for comfortable typing
- Key-by-Key Customizable Backlighting with Blue LEDs with adjustable brightness and per key programmability to light up just the keys you need. Save the combination for your favorite game directly to the keyboard.
- Contoured, Textured WASD Keycaps - Keep your eyes on the action with easy to locate FPS keys
- Brushed Aluminum Chassis - Professional-Grade look and feel plus the rugged durability needed for hours of gaming
- Full Key Matrix Anti-Ghosting with Full N Key Roll-over on USB - Every keystroke translates into accurate gameplay¡Xeven when multiple keys are pressed.
- Detachable full length wrist rest - Soft touch design that¡¦s comfortable for hours of play and easy to remove if it gets in your way.
Specifications:
- Cherry MX Brown mechanical switches
- Replaceable contoured, textured WASD Keycaps
- Up to 1000 Hz USB report rate
- Deep Blue LED backlighting with key-by-key programmability to light up individual keys
- Aluminum unibody construction for increased strength, durability and rigidity
- Six dedicated multimedia keys
- STOP, PREVIOUS, PLAY/PAUSE, NEXT, MUTE, VOLUME UP/DOWN roller
- Windows Lock key for uninterrupted game play
- Product Dimensions: 438 x 166mm
- Product Weight: 1200g
Was £109.9 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Corsair Vengeance K70 Gunmetal Cherry MX Blue Mechanical Gaming Keyboard (CH-9000058-UK) @ £89.99 inc VAT
The Corsair K70 is a fully mechanical, backlit keyboard that’s designed for performance gaming. The built-in Cherry MX Blue switches deliver tactile feedback with an audible click. Every key is individually lit for brilliant backlighting and easy customizability to highlight important functions. The brushed aluminum structure provides rugged durability and a professional-grade finish. Replaceable contoured keycaps make it easier to find critical WASD keys—even in dim light. Plus the Full N Key Roll-over on USB and 100% Anti-Ghosting mean that every key you touch translates directly into the game.
Product Features:
- Cherry MX Blue Mechanical Switches - Great gaming performance with tactile feedback and an audible click for typing.
Specifications:
- Cherry MX Blue mechanical switches
- Additional keys for WASD and 1-6 number keys
- Selectable 8ms, 4ms, 2ms, 1ms and BIOS mode
- Warranty: Two Years
Was £109.99 Inc. VAT
ORDER NOW
Huh, I've already got one of these Gunmetal + Cherry browns. Had it for over 4 months as it was the standard color for the cherry browns (K70). Confused how this is a limited edition run.
Aside from that, the keyboard is great. Rock solid build and lovely to type on.
because the gunmetal cases were made EOL and replaced with the black cases.
backlights are blue
will edit descriptions now to make it clearer./
Hi Guys
Still waiting on the stock to land.
Just a heads up, we have already pre sold half of the stock of these on the brown switch. Plenty of blues left but they are getting snapped up quickly too.
As a rough estimate, we will have around 20 or less of each colour switch left in free stock when they land.
Currently have a Razer Mirror Lycosa, however I feel it is reaching the end of it's life.
What would be a suitable replacement considering the cherry switches? I really like the Mirror Lycosa (actuation 45g), as it is very quiet and nice to type on - whether essays or gaming.
Is there a suitable Cherry switched Corsair Keyboard that would mimic the Razer keyboard?
Hi Guys
whats the difference between the blue and brown? Are they the LEDs?
