Prefetch and Superfetch with SSD's
25 Mar 2004
Fareham
Hey guys, how many of you with SSD drives disable prefetch/superfetch? I am wondering if they're worth keeping enabled or not. I have an Intel X-25M 160GB drive by the way
Windows 7 will do it for you:
Will Superfetch be disabled on SSDs?
Yes, for most systems with SSDs.
If the system disk is an SSD, and the SSD performs adequately on random reads and doesn’t have glaring performance issues with random writes or flushes, then Superfetch, boot prefetching, application launch prefetching, ReadyBoost and ReadDrive will all be disabled.
Initially, we had configured all of these features to be off on all SSDs, but we encountered sizable performance regressions on some systems. In root causing those regressions, we found that some first generation SSDs had severe enough random write and flush problems that ultimately lead to disk reads being blocked for long periods of time. With Superfetch and other prefetching re-enabled, performance on key scenarios was markedly improved.
Source
