£100 win in November, 15K held.
Takes this years winnings to £425.
Strange, when I log in there's no notification, no message, but when I go to prize history, there it is.. Must be slow updating the system.
Mine still says last win was last months..this happened last month though and a day later I seen it update in the website. I will check again tomorrow as mine usually updates a day after everyone else's updates
Go to prize history, that is updated faster than the banner and account balance etc.
Partly timing of course they have lot to update and send notifications for.
How much do you have invested ? It's not really worth it unless you have atleast 25-30k in as the wins are minimal and even then you don't usually see the higher wins until you have 30+ in.After I take my money out of PBs and I'm back to normal saving I don't think I'll do it again. It really seems like although the overall. Percentage rate is.. 4pc?..and it's tax free it is for most obviously a lot worse than that.
I'm only in now to basically gamble with the interest as my other option is a flexible isa for 6 months with a drip feed of 2k a month. So I decided to just gamble the interest
Where are you going to invest instead ? Do you have tax implications ?
Its quite variable.
Also the amount is key. You need a decent amount to stand a good chance of being around the headline rate. IIRC its around £20k that you should not be noticeably below the headline rate.
Otherwise your % is going to vary significantly. If your lucky it will be very high, if your unlucky it will be very low.
That's a damn good return£175 on £6,900.
Brings me up to £400 since last October. Helps in part towards the wedding.
Ouch.0 from £49k
