Preparing for first loop
20 Jun 2013
Hi guys, after much Umming and Ahhing, I've decided to go for my first Water cooling loop I've already preordered the snazzy Phanteks Enthoo Primo case, and I'm just getting a list of fittings etc. I just wanted to ask people's thoughts on it and is there something glaringly obvious I've messed up on.
YOUR BASKET
1 x XSPC RayStorm CPU WaterBlock (Intel) Copper £104.99
1 x XSPC Razor GTX 770 GPU Waterblock £91.99
1 x Hardware Labs Black ICE Radiator SR1 420 £89.99
2 x XSPC D5 Vario (Body + Screwring) £56.99 (£113.98)
1 x EK-BAY SPIN Reservoir - Plexi CSQ £55.99
1 x EK-RES X3 250 Reservoir £51.98
2 x Monsoon 16/10mm (ID 3/8 OD 5/8) Free Center Compression Fitting Six Pack - Gold £27.95 (£55.90)
1 x Monsoon 16/10mm (ID 3/8 OD 5/8) Free Center Compression Fitting Six Pack - Matte Black £27.95
1 x Bitspower Matte Black Mini Valve With Black Handle £16.98
2 x Koolance QD3 Female Quick Disconnect No-Spill Coupling, Compression for 10mm x 16mm (3/8in x 5/8in) £12.95 (£25.90)
2 x Koolance QD3 Male Quick Disconnect No-Spill Coupling, Compression for 10mm x 16mm (3/8in x 5/8in) £12.95 (£25.90)
2 x Bitspower G 1/4" Matte Black Dual Rotary 45 Degree IG 1/4" Adapter £11.99 (£23.98)
2 x Monsoon 19/13mm (OD 3/4) Rotary 90° - Gold £9.95 (£19.90)
2 x Monsoon 19/13mm (OD 3/4) Rotary 90° - Matte Black £9.95 (£19.90)
2 x Monsoon 19/13mm (OD 3/4) Rotary 45° - Matte Black £9.49 (£18.98)
2 x Monsoon 19/13mm (OD 3/4) Rotary 45° - Gold £9.49 (£18.98)
2 x Mayhems X1 Clear Premixed Watercooling Fluid 1L £7.99 (£15.98)
1 x ModMyMachine Shoggy Sandwich V2 for your Watercooling Pump £6.98
1 x XSPC G1/4" T Fitting (Black Chrome) £3.95
3 x Koolance Radiator Mounting Screw & Nut, 25mm £2.99 (£8.97)
1 x XSPC G1/4" 10mm Male to Male Fitting (Black Chrome) £1.79
1 x XSPC G1/4" Plug (Black Chrome) £1.55
Total : £816.59 (includes shipping : £11.75).
I'll be ordering the EK dual pump top from a competitor site as Ocuk don't stock it, so some help and comments from you water cooling masters would be much appreciated ;)
will be adding 2nd and 3rd cards at a later date. fancied the look of having 2 reservoirs, and the potential for 2 loops sytem later, the dual pumps atm for redundancy.
Well the new case is not due in till September, so I can wait a while till Ocuk get the stock in, I'd rather buy all the components from Ocuk anyway, it will be an expensive month, as I'm aiming for a new 4830 cpu too
Anyone used a drain port that is removable using Qdc's, was thinking I could just use a set of Qdc's on a T fitting and just plug it in when I wanted to drain asystem, and then remove it when I'm done.
Are there any drawbacks?
Yeah I originally had that in mind, but I just had this idea to keep the entire loop clean, just add the drain port when I needed to. I don't even have a good reason as to why
I've done that with drain tubes. It was in a m-atx case which didn't have a whole lot of space available, and I wanted a long tube to drain water away conveniently. It doesn't work so well as a very short T line because bubbles tend to get stuck in the disconnect.
T block -> ball valve -> quick disconnect, then a tube with the matching quick disconnect. The ball valve was because I don't have complete faith in the quick disconnects. I've since given up on the disconnect and have value -> blanking plug, which I unscrew to drain the loop.
The cpu block seems to cost twice as much as I would expect. It's hard to imagine that's thermally justified, so I guess it's the look you're paying for. Frightening cost of fittings too but I'm sure you've noticed that!
It might be worth spending a hundred or so on second hand parts first - old block, sort-of working pump etc. I broke my first pump (a Laing DDC :( ) within a day of owning it and that made me sad. It might also be worth plumbing it together in a spare computer first, just to work out any kinks in your technique. Especially given that second hand parts tend to work much as well as new ones - nothing much to go wrong with lumps of copper - so you may end up sticking with the low cost loop for ages.
Thanks for the advice JonJ678, I'll have a root around on the net and see what I can find in regars to preowned pieces. I've never considered that as an option before for a loop just on the off chance that something is broken etc
