Ive been reading the forums everyday for a while now and have decided to take the jump and do my first overclock. My setup is...
GA-x48-DS5
Q9550
Corsair dominator 1066 6GB ram (2 x 1GB and 2 x 2GB)
H50 cooler
Antec 902
Downloaded the testing programmes and ran prime95 for a while and got the following temps.....
Uploaded with ImageShack.us
My temps idle at 40,34,35,32 although ive never seen core 0 go below 40 so i dont know if the sensors is stuck.
Think my idle temps may be a tad high but i think my load temps are decent?
The only change i was going to make was to up my multiplier from 8.5 to 9x333 which will OC my cpu to 3Ghz and then il run prime for a few hours. Is this a good idea or should i tweek a few other settings aswell. Any help/advice would be awesome as i said earlier this is my first OC which is an exciting prospect but id rather have some input before i go ahead with anything incase i brick any of my componants. Thanks in advance
GA-x48-DS5
Q9550
H50 cooler
Antec 902
