pressure from fuel cap?
27 Aug 2003
West Midlands
for some strange reason recently, when I go to fill up the car, i remove the fuel cap, and it makes a dumpvalve like noise PCCCHT type of thing, where pressure is being released... It's not normal I would imagine, but what could cause it? :confused:
Ta
ScoobyDoo69
it means that as the engine draws the fuel out of the tank the air can't get in to replace it fast enough. I guess there should be a breather pipe somewhere that might be blocked, don't worry about it ;)
HT
A friend of mine had same type of problem with his Honda Civic some years ago. It would actually build up pressure in the tank, He took it back to the dealer a few times but, I dont ever recall him saying it was cured.
As already said it must be a blocked tank vent I would have thought.
Nothing wrong at all, fuel injected cars need a pressurised fuel tank, your just releasing the pressure in the system, my MX does the same thing :)
L0rdMike said:
Is it not air being sucked in rather than out though? :p
not a clue... lol
I've read somewhere before that there is something called a carbon catcher.. or was it canister? that fills up, so just empty it, but I honestly have no idea about that!
Nope thats just for the car to come in line with new enviromental standards, if your getting enough fuel in that you have serious problems it, should be tiny amounts.
In a car with electronic fuel injection, the injectors squirt fuel into each cylinder. Fuel in this type of system is kept highly pressurized with the help of a pressure regulator. Due to the high-pressure system, the fuel lines must be made of metal. Sometimes the fuel filter in a high-pressure fuel injected system is placed in a low-pressure section, and may be connected to rubber hoses with hose clamps, much like in a carbureted system. However, the fuel filter in a high-pressure fuel injected system is usually equipped with a threaded fitting on each end that screws into the fuel lines on either side.
Like i said nothing wrong ;)
Thats why when changing the fuel filter you should take the fuse out for the fuel pump crank the engine, this will stop petrol spraying all over the place when you take the fuel line off ;)
It's actually caused by oxygenated/methanol mixed fuel being shaken. When shaken these type of fuels "foam" and give off vapors. It happens all the time over here as ALL fuels are either oxygenated or methanol mixed or both.
It's nothing to worry about and is a normal condition for these fuels.
