The problem with these cheap pressure washers is that the head is made of aluminium and water eats aluminium over time. You use it once, store it away and when you use it again the unloader valve is stuck because the water has corroded the pump head. Won't last 5 mins in high limescale areas either.
We used to use concrete cleaner as a limescale remover in the big industrial washers. Put an ally head in the cleaner overnight and it would be like putty in the morning.
So avoid ally heads and buy brass.
