This when its in stock. https://www.directhoses.net/collect...asher-upgraded-wire-reinforced-hose-quick-fit
That's weird the nilfisk patio cleaner for me does a brilliant job, so much faster.The patio cleaner that came with my Nilfisk is a piece of crap. The pressure washer itself is great but the plastic patio cleaner is good for nowt, just leaves swirly marks all over the patio. I found it better and quicker to just use one of the nozzles and clean it methodically.
Stilly question... just purchased a nilfisk 125: Nilfisk 125 Do I need to buy a sperate hose to connect it the external tap?
Normal garden hose with normal hose connectors.Thanks silly question number 2. Which hose the manual isn't specifically clear and what is required
Normal hose as above, just make sure its connected fully. Mine is a really tight fit and a bit of a pain to get onThanks silly question number 2. Which hose the manual isn't specifically clear and what is required
+1Tested it using the Rough nozzle at full power on an aged white plastic garden chair and it was removing the dirt and at least a millimetre of plastic.
I find the Karcher patio washer is excellent.Thread bump..
What's a good pressure washer for slabs?
Same as previous? Any new models?
