Previous OC Spec Build Upgrade....
10 Feb 2010
Oxfordshire
Good afternoon all - cant believe its been so long, but, back in Dec 2017 I came on here to seek advice on a PC build, yes, kids are still around..... however, I did learn how to change what the power button does when pressed :D! Subsequently purchased the items and built the system previous post
I went with:
  • AMD Ryzen 5 six core 1600
  • Gigabyte GA-AB350 Gaming 3 motherboard
  • ID-Cooling FrostFLow 240 CPU cooler
  • Asus GTX1070 Dual OC card
  • Cougar GX V3 600W power supply
  • 2x 8gb DDR PC4-2400 Team Group Night Hawk RGB RAM
It has been absolutely faultless. Unfortunately though, with windows stopping support for WIN10 and my system not being able to support WIN11, I find myself looking to upgrade. The above still works fine for me, small amount of gaming and AutoCAD/Revit work, nothing strenuous, although think I should stick in some more RAM.
In terms of budget, I don't have much. I'd like to reuse as much as possible, what are peoples thoughts?
Cheers Chris
I'm normally strong in favour of upgrading the CPU and RAM on AM4, especially from a 1st gen CPU, but since DDR4 has gone up so much, AM5 makes more sense than before. It depends though, just another 16GB won't be too bad.
