Price VS power consumption
17 Mar 2005
With all the price movements, new socket types new cpus types 45nm etc in mind
What is the best value setup currently for a replacement computer which sits on 24/7 with sub 2% cpu load (based on a current socket 939 amd singlecore 3200)
In general what setups are using the least power?
And who currently has the best (auto) underclocking options.
Is there any detailed write up on this else where?
Depends what you want it to do....sounds like the Celeron E1200 might be suitable. Can probably undervolt it to .8V or so ...maybe even less
i think the e1200 does that fine, you could always grab a 4350 or something though for HD playback.
if its a c2d it has to be a 45nm core. the p8xx mobile cpu's are stellar for performance/watt, but not cheap. when they filter down to the budget chips, they will be phenominal
E5200 all the way and undervolt it. Look at Big.Waynes on here, his whole E5200 PC uses about 85w under full load!
Avoid Celeron's, they are crippled so much its not worth having for the sake of a few less £'s
Head over to SPCR, some dude built an E5200 based rig that uses 50W! He even used a 4670, it's on the forum...
Hmm that sounds ideal depending on cost, could you spare a min to dig out the url? I have spent some time over there and can not find the thread in question, Thanks
that says 90w to me......
As you can see, it's an oldish thread, I got 50W from memory... It wasn't until I looked up the thread again I saw that was the idle wattage.
It does use less then 50W at idle, but around 90W at full whack. Still pretty impressive when you consider many systems use 3 or 4 times that power and don't run a lot faster. :)
