Prime failed after 7 minutes on my Q6600.
25 Nov 2007
Crewe
Thread #2
FATAL ERROR: Rounding was 0.4998779297, expected less than 0.4.
Ram is at 500mhz at 4-4-4-12 at 2.2v
Cpu-z reports voltage at 1.368V
Temps didn't go over 60*C
What can make it fail?
I set them to 5-5-5-15 doing test now.
Core voltage is 1.320V now i have it set to auto in BIOS
I guess i have to manually set the voltage.
It worked for 15minutes than it failed on thread 4
Rounding was 0.5, expected less than 0.4
I will go and manually set the Vcore. What do you think 1.4?
I set it to 1.45 in BIOS but its only showing 1.408V in CPU-Z is that right?
Now its 1.352 underload.
after 3 minutes the cores are
62*C
62*C
59*C
59*C
and PC Pribe 2 is reporting the cpu is 66*C
Hi mate, set the voltage damper to enable in the bios if you've not done so... works wonders for vdroop
