- 13 Aug 2004
- England
Noob question; Is orthos for dual core cpu's only?
$loth said:Noob question; Is orthos for dual core cpu's only?
kitfit1 said:Yes. Stress Prime 95 is for single cores.
That's not the way you do it, just install Prime95 once and then make two shortcuts.The Asgard said:You can use prime 95 on dual cores by having 2 copies of the program running ( make 2 dirs of prime95) and setting the instance to each core
Big.Wayne said:That's not the way you do it, just install Prime95 once and then make two shortcuts.
His way works as well as it loads one core per instance anyway without setting affinity. An even easier way i found was just to keep it in the zip file and open it twice, it makes 2 different temporary folders and loads each core up. So while you way works, theres more than one way to skin a cat.justinwilkin said:Basically I've been dabbling in some amateur overclocking of my p4 620 (3.2ghz running at 3.5ghz).
It seems ok but I want to stress it and find out if it's stable.
I've just downloaded prime95, and I was wandering how long I should run it to see if my overclock is trully stable, and what will happen if it isn't?
I'm slightly worried as before this overclock, I tryed to get it to 3.6 but it screwed up my windows installation hence why I'm not going that far.
Any help would be appreciated![]()
Brwmogazos said:You need 2 instances of prime...not on blend tests...
try small and large FFTs...
then blend too
It's not a dual core CPU, unless you mean it can run two because of hyper threading?
justinwilkin said:I can't run two instancesIt's not a dual core CPU, unless you mean it can run two because of hyper threading?
I ran it with large FFT's for 8 hours over night and it was fine. No errors at all, so I'll give it a go with small FFT's later![]()
i used to start stability testing my ring before going to bed....leave it for 24+ hours(i know quite a long waiting time for a student with just one pc) and then see if the test was running fine...
Wish i was mad into it these days but i just overclock whatever the cpu can do on air and stock volts, most i do is a 3rd party coolers these days and thats for quiet more than overclocking.
