Primo / Pro decision, help please...
12 May 2010
West Bromwich
I need to buy a new case in the next couple of weeks, and I've narrowed it down to either the Enthoo Primo or the Pro. There are a couple of things I am unsure about though, as to how the decision will sway. I was wondering if anyone could shed some light on these...
- Top rad will be an RX360, and my current res is the XSPC D5 Dual Bay res. Would these fit ok in the top of the Primo, or do you reckon it would be too tight behind the res to get the hoses through?
- If it doesn't, I would have to go with the Pro and the Photon tube res. Would that fit in with a 690 and an RX360 in the top?
- Can you get an RX240 in the bottom of the Pro without removing the drive cages.
Thanks...
I will be trying to fit an RX360 and and XSPC D5 Dual Bay res in my Pro this weekend so will let you know. Shame as I originally bought the Photo 170 but it won't fit as I have an EATX motherboard and a long graphics card - mine is a 670GTX.
