Do you need to file/sand the edges after a cut with this? Also I thought that the pressure of the system is the only thing keeping the tubing on, as you can't use compressions? Hopefuly what I read doesn't apply to this and as I would much prefer to use these.
If you check the Primochill facebook page there is a video of a guy bending the acrylic tube, i'm buying lots as soon as it's released to have a play about with.
Yeah, they are called PrimoChilll rigid ghost compression fittings.
Typical that I recieved a whole bunch of tubing from E22. Practicing bends as I write this for my Ft02 build.
Why the coloured tubing looks horrible
