** PRIMOCHILL **
I had to swap some tubing out today so I thought I'd share a pic of some 2 week old tubing which has had EKoolant inside vs some brand new tubing. I'll upload a pic with filled tube tomorrow.
Sweet will get this to replace my tubing this year :).
My xspc tubing is holding up great and no clouding so far either.
Hi, l had xspc blue tubing replaced it after 2 year's with EC6 coolant which was as clear as the day l filled the loop.
hopefully
I really hope so :-)
I looked at crystal link for my new loop, but stock levels everywhere of the fittings are abysmal. I've basically given up on it. Are bitspower fittings really difficult to get stock for?
If the primochill rigid tube and compression fittings work as well as I hope, I imagine it will be VERY popular.
E-I
Hopefully when you get the 1/2 - 3/4 acrylic tubing in I will definately buy. One question though what fittings are available to use for this tube as crystal link would be too small.
Think you would need to use the Primochill compression fittings made to go with the new tubing. Still they will be offering them in quite a few colours I believe - have a look on the primochill site, as they have info/pics etc.
Mark
Just had a look through their website. i was able to find the acrylic tubing but did not anything about the crystal link type fittings or compressions.
Anybody able to link me to one please :)
Hi,
Just went to Primochill site and it is not working - just updated their site as well!!! Then I found this
http://forums.pureoverclock.com/pri...fittings-knurled-grip-4-packs.html#post159376
At least it gives you an idea. Have a look on primochill Facebook page - as there are pics and info about the compression fittings for the tubing.
Mark
Hi,
Mark
Not bad, very nice indeed. I'll see if I can trawl out any more pics or info about this. Unfortunately I dont have facebook, or should I say I chose not to ha ha.
Anyways thanks for the link
