printer connection, wi-fi or cable
Step 1: Go to Control panel - Power options
Step 2: Now click on the "Change plan settings" next to the selected power plan.
Step 3: Click on "Change advanced power settings".
Step 4: Now, expand the "Graphics settings".
Step 5: Make sure the "Maximum performance" is selected on both battery & plugged in options.
Step 6: Apply the settings, restart your notebook and then check the performance.
Step 7: I would also recommend you to check the other settings under the advanced power options settings if the issue still persists.
For More
Think you posted in wrong thread. ...
Hi I have a canon ts5151 printer that has been wifi printing fine from my iPad and iPhone fine but now it has spopped and says printer offline anyone know how I can fix this or a link to go to.cheers
Check the printer's network settings and make sure it's connected to your wireless network and has an IP address.
From a web browser you should be able to browse to the printer, e.g. http://192.168.x.x/ to make sure it is online.
Open File Explorer and click on Network, if your printer is listed click connect.
