Printer issues
9 Sep 2008
Glasgow
Evening :)
Just got a new cheap printer epson sx235w.
and a pack of cheap ink for a fiver from the bay, as i don't print very often.
problem is this....
Could this be due to the cheap ink? or what?
Any help much appreciated guys.
Did you not get starter cartridges to test? When we talk about cheap inks, £5 is a little too cheap. Check out Inkrite who make decent cartridges that don't cost the earth.
Weird that you didn't get any starter cartridges with it. I guess you could try another set of better quality cartridges and if you have no luck then RMA the printer for another of the same model. I suspect it's the cartridges however - does this happen regardless of what colour you try and print?
That's the cartridges.
Look at Refresh Cartridges for good quality.
You may need too return it, if so remove the non official cartridges as they would void the warranty.
