Printer setup with roaming profiles?
30 May 2004
Uk
I am just setting up a a small network. The server is running Windows 2003 server and the terminals are running XP Pro. What I'm wondering is, what is the best way to setup the terminals to connect to a network printer (Oki colour laser with ethernet port).
Cheers
in answer, as far as i know in 2003 w/ XP the printers if added to a user profile as a network printer should remain there wherever the user logs on.
Don't quote me on that, i'll steal someone's username and passwrod and check it when they all go home.
I'll quote you on it, since you're correct :)
I was quietly confident :) but one thing you learn working in IT is never give anyone a straight answer unless your 120% sure you can do it.
:D 1000th post!! woooooooooooo.
