Printing Problems...
Man of Honour
17 Feb 2003
Chelmsford
I have a HP PSC 2170 Printer and quite a large Sage document to print.
When this prints the whole PC just freezes and doesn't print.
All other normal size documents are fine.
I had a quick look in the advanced printer properties and the spooling options are set to "Start Printing immediatley"
Is this correct.. what else can I try?
Thanks
Can you print to PDF or such? Or a different printer?
I used to use PrimoPDF for printing to PDF, not sure whether it still exists...
DAS said:
Could it be that there is insufficient printer memory?
I think it is.. the doc is showing 337Kb by page 3 :eek: so if i'm right for 100 pages that's going to be 1.1 GB??????
I thought the printer would use the system memory/page file?
1.1gb!?
110kb x 100 = 11mb :)
Try spooling the whole job to computer memory before sending to the printer. It shouldn't be too much of an issue, a file that size, I've had to endure people's Publisher printing problems before, and they're huge files.
gumbald said:
1.1gb!?
opps :D
How is that done? by selecting "Start printing after last page is spooled"?
