Pro or XT
I would go for this if it's within your budget. Amazing, silent cooler for not much more money.
If not, then the Sapphire X1950XT is the better choice of the two you selected. :)
The XT costs about 25% more than the Pro, but runs about 25% faster. Both good cards, so completely up to you.
What res are you gaming at? Also, if you would want to upgrade to a dx10 card later on it might make sense to get a Pro and save some dosh.
Before you decide on the Sapphire, read THIS
If you can afford it go for THIS one!
I have one and i cannot fault it...as well as overclokcing extremely well, its fast and very very quiet.
